Printing with ArcGIS Web App Builder 1.0
12007
13
12-30-2014 10:25 AM
YaneevGolombek
Hi. I've been playing with the Beta versions of new Web App Builder and just downloaded the 1.0 version. A great tool for simple web mapping apps. The only issue I've been having with all versions is the print function. Every time I try to print with every format, I get an "Error, Try Again". Just curious if anyone else out there has experienced this and/or have found a way around it. I was hoping that any bug would be ironed out in the Beta versions prior to release, but it appears to be doing the same thing (on my end at least...).
(pic attached)
Yaneev
MelissaPrindiville
Hi
Was there ever a solution to this.  I am hosting a WAB solution however using the Arcgis Online print service and am getting the Error, try again. how do i get the print widget to recognize my proxy secure username  and password credentials.
-Mel
YaneevGolombek
Hi. I personally never solved this, though when I posted this, WebAppBuilder was a standalone app and now its built in to ArcGIS online, where I use it most. I should try it again via ArcGIS online to see if I have the same issues.
Yaneev Golombek, GISP | GIS Projects and Applications Lead | Merrick & Company
T: +1 303-353-3939 | www.merrick.com<http://www.merrick.com/>
Engineering | Architecture | Design-Build | Surveying | Planning | Geospatial Solutions
AndreV
Hi. Maybe you should give this a try: Add your secured services to your arcgis online account as element and save the credentials within. Then add those layers to your webmap.
gdi-hohenlohekreis.de
BillSpiking__GISP
Hello.  We had the same printing issue using the workflow as described by Andre so a colleague of mine called Esri support and they reference Bug# NIM-091603 (http://support.esri.com/en/bugs/nimbus/TklNMDkxNjAz).  The only workaround we found was by using the LocalLayer widget.
Here's our initial setup that was not working due to the bug referenced above:
  • We had secured services (with creds stored) feeding an AGO web map.
  • Using WAB Dev 1.2 we added the web map with the secure services and the print widget with our own print service.
  • We deployed the WAB on our web server and used the Esri proxy that referenced our AGO creds.
Our proxy was authenticating correctly to AGO and obtaining access to the content item that had the embedded credentials, but the system wasn't able to obtain a token for access to our secured service for printing.
