Predictive search suggestions
1178
09-20-2016 08:49 AM
BlakeTerhune
The help document for the search widget says
When you enter a place-name or a keyword in the search box, you see suggestions as you type.
I see that it works with the default world geocoder but I can't seam to get this functionality to work with my own feature layer or geocoder. Are there any special configurations/settings that are needed to get this to work? I want it to show a list of possible matching search strings as you type (before hitting enter).
RobertScheitlin__GISP
Blake,
   Your service has to support suggestions:
NOTE: Suggestions are available if working with a 10.3 geocoding service that has suggest capability loaded or a 10.3 feature layer that supports pagination, i.e. supportsPagination = true.
http://www.arcgis.com/home/item.html?id=d50dad552aca40c98a090e310ab8e038
Blake,
BlakeTerhune
Since we're on 10.2.2, looks like that would be the issue. Thanks again for your quick, helpful replies!
