Photo Thumbnails and a Point Feature Class
3667
9
09-20-2016 11:43 AM
TimHayes1
I have a Point Feature Class. In the attribute table I have 3 photos.
I want to be able to click on a point, and have the photo thumbnails appear in a way that allows a user to scroll through the thumbnail list of photos and then click on a thumbnail photo for a larger view.
Is it possible set this up with AGOL WebApp Builder? If so, how would I go about doing it?
Tags (3)
RobertScheitlin__GISP
Tim,
   You can do this by setting up the pop-up media for that layer in the webmap.
Here is an example webmap that shows the traffic photo for Louisville, KY:
http://www.arcgis.com/home/item.html?id=18df7255535b41f8ac37e7855222a9ef
Tim,
TimHayes1
I know how to do this with AGOL, but need some help trying to figure out how to do this with the WebApp Builder. Any ideas?
Tim,
  Popups are configured for layer in the Web Map (AGOL) not in the WAB UI. Unless you are talking about using LL Widget.
TimHayes1
Yes, the LL Widget. What do you know?
Tim,
   Setting up popup media infos is not supported by the LL widgets UI. I am seeing if I can get it working by editing the widget json directly. I will let you know.
TimHayes1
Thanks, Robert. Would be nice if you could make it work like you did a similiar thing in Flex.
TimHayes1
Have you seen this?
GitHub - magis-nc/esri-webappbuilder-widgets-ePopup: Widget to customize popup behaviour in WebApp B...
Before I give it a shot, I was wondering if you tried this with the LL.
Tim,
   Here is how you manually configure an Image in a popup for LL Widget (you need to manually edit the config_Local Layer Widget.json):
        "type": "Feature",
        "url": "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_PublicSafety_Louisville/...",
        "name": "Traffic Cameras",
        "opacity": 1,
        "visible": true,
        "showLabels": false,
        "trackEditByLDAP": false,
        "limitEditByLDAP": false,
        "popup": {
          "title": "{DESCRIPTION}",
          "fieldInfos": [
              "fieldName": "URL",
              "label": "URL",
              "visible": true
              "fieldName": "ONLINE",
              "label": "ONLINE",
              "visible": true
              "fieldName": "DESCRIPTION",
              "label": "DESCRIPTION",
              "visible": true
              "fieldName": "LAST_UPDATED",
              "label": "LAST_UPDATED",
              "visible": true
          "mediaInfos": [{
            "title": "",
            "caption": "",
            "type": "image",
            "value": {
              "sourceURL": "{URL}",
              "linkURL": "{URL}"
TimHayes1
Thanks, Robert. With this wonderful bit of code, I can take it from here. You are awesome!
