PDF Links in WAB
4908
03-23-2016 04:15 AM
PatrickMcGarry
Can I link to a PDF file using a widget in Web App Builder. The PDF link is in a field in a polygon FC.
PatrickMcGarry
Thanks for all your replies, I fixed this by editing the configure pop-up for the layer in the Map on AGOL. Under Pop-up media I set the link to the image ref field which contained the full location of the PDF.WAB_PDF_Link.JPG
RobertScheitlin__GISP
Patrick,
  If you field contains a full url then the OTB query widget and the Attribute Table Widget will convert them to hyperlinks. If your field is not a full url then the eSearch will allow you to define your link fields and even add a url prefix and suffix.
JamesCrandall
Yes.  We use the About Widget to show a list of .pdf help documents as well as .mp4 "How To" videos that are launched by clicking on the url's pointing to each one.  We place the source files in the same folder the WAB is deployed to.
PatrickMcGarry
Patrick,
  Glad you got this worked out don't forget to mark this thread as answered.
