PanelManager.showPanel() does not apply LaunchPad theme anchorbar controller icon colour to panel header
2837
04-28-2016 02:40 PM
AndrewTerwiel
I have the following code that successfully shows a widget panel. When using the Launchpad theme, the colour from the widget's button icon in the AnchorBarController doesn't get applied to the panel header. It should look like this:
but instead looks like this:
Also, when minimised the panel looks like this:
when it should take on the colour of the button icon in the AnchorBarController like this:
The code:
var myWidget = null;
              arrayUtils.some(this.wManager.appConfig.widgetPool.widgets, function (aWidget) {
                  if (aWidget.name === widgetName) {
                      myWidget = aWidget;
              if (myWidget) {
                  // check for presence of the AnchorBarController
                  var controller = this.wManager.getWidgetsByName("AnchorBarController");
                  if (controller.length > 0) {
                      this.pManager.showPanel(myWidget).then(lang.hitch(this, function (panel) {
                          panel.setPosition({ top: 120, left: 10, width: 350, height: 480, margin: 10, index: 0 });
                  else {
                      this.pManager.showPanel(myWidget);
Does anyone know of a way to get the icon colours to apply to the panel?
RobertScheitlin__GISP
Andrew,
Here is the fix for that:
_showWidget: function (widgetName) {
        this.wManager = WidgetManager.getInstance();
        this.pManager = PanelManager.getInstance();
        var myWidget = null, panelConfig = null, dockableItem = null;
                myWidget = aWidget;
        if (myWidget) {
            var abc = controller[0]
            arrayUtils.some(abc.iconList, lang.hitch(this, function (wpanel) {
              var pc = wpanel.getConfigForPanel();
              if (pc.name === widgetName) {
                wpanel.setOpened(true);
                wpanel.setPanelIndex(abc._calPanelIndex());
                panelConfig = wpanel.getConfigForPanel();
                dockableItem = wpanel;
                return true;
            this.pManager.showPanel(panelConfig).then(lang.hitch(this, function (panel) {
              panel.setPosition(panelConfig.panel.position);
            abc._addToOpenedIds(dockableItem.config.id);
          } else {
AndrewTerwiel
Thanks, Robert.
