OverView Map widget window is blank at full extent
1469
03-24-2017 01:43 AM
DeepikaJain1
Hi Folks,
I am using overview map widget through web app builder and have configured it with map, the map service is cached. However, it shows the map in overview map only after 5000 scale, before that it only shows the blank screen with the rectangle.
RobertScheitlin__GISP
Deepika,
   Are you using a non esri basemap? If s does it have a scale dependency set?
