Near Me widget Inaccurate buffer distance
4108
6
11-01-2016 01:45 PM
HowardKim
Hi, I created a ArcGIS app with webappbuilder through ArcGIS online. I used Near Me widget to get the distance between my location and nearby hydrant point. Basically, Near Me widget is set to find hydrants near my location by the buffer distance that I can set with a slider bar. However, it seemed about 30% short of the actual distance, so I added a Measure widget to the sidebar and compared the distance with Near Me widget'z buffer distance.
As seen from the picture, the Near Me's buffer is set to 179 ft. from the bright square location and displays yellow ring. But when you used Measurement widget's distance measure tool, you can see the blue line distance is 172.8 ft (result panel on left), which is longer than the buffer ring of 179 feet.
Any comments or feedback will be helpful, thanks!
DerekLaw
Esri Esteemed Contributor
Hi Howard,
This is a known bug:
BUG-000095093 - The distance displayed in the NearMe widget search results in Web AppBuilder is not the same as the Measure tool measurement result
and we are working to address it.
Hope this helps,
RobertScheitlin__GISP
Howard,
  I have seen a thread stating the exact opposite:
https://community.esri.com/thread/180343
You should call esri tech support.
DerekLaw
Hi Howard,
Hope this helps,
HowardKim
Derek, thanks for your comment. This is really good to know.
by Anonymous User
Not applicable
Am I missing something regarding the solution? This has been an issue for me on several organizations over the last year. As far as I can tell, BUG-00095093 was never resolved. Anyone can open the Near me, Situational Awareness, Incident Summary, and other widgets and get different distances than the measure widget or reality.
WilliamMPelchat
A colleague of mine discovered this same issue with the Near Me widget on AGO, today 5/9/2022.
I submitted it to ESRI support.
WilliamMPelchat
We found the Near Me widget has a default to euclidean.
