Move auto launch widget
5519
10
06-02-2017 09:13 AM
CCWeedcontrol
I can't figure out how to move the Legend and ESearch windows down at launch.
Pic one currently show how the ESearch appears at launch, it covers up toggle buttons. Pic two is how i would like it to appear at lunch it doesn't cover up the toggle buttons. What do i need to change to get to Legend and ESarch auto lunch to move down.
RickeyFight
What you need to do is change the top style for that widget
in the style.css found here:
\WebAppBuilderForArcGIS\server\apps\7\themes\LaunchpadTheme\widgets\Header\css
Assuming you are using the launchpad theme and your panel was # 30
You need to past in:
div#_30_panel {
 top: 150px !important;
You can find your panel number by look in the config.json or inspect the element and add a new style rule.
 "position": {
 "right": 100,
 "top": 20,
 "relativeTo": "map"
 "placeholderIndex": 1,
 "id": "_30",
 "name": "Legend",
 "label": "Legend_2",
 "version": "2.3",
 "closeable": true,
 "icon": "/webappbuilder/apps/7/widgets/Legend/images/icon.png?wab_dv=2.4",
 "uri": "widgets/Legend/Widget",
 "config": "configs/Legend/config_Legend_2.json",
 "openAtStart": true
It should then load at 150px down from the top of the page. If 150 is not enough adjust the number.
RickeyFight
What theme are you using?
RickeyFight
div#_30_panel {
 "position": {
 "right": 100,
 "top": 20,
 "relativeTo": "map"
 "id": "_30",
 "name": "Legend",
 "version": "2.3",
 "closeable": true,
 "openAtStart": true
CCWeedcontrol
That did the trick, thank you!
CCWeedcontrol
well it did move it down but now the window only moves in a fixed horizontal way along the screen.
I need to be able to move the window around anywhere.
RobertScheitlin__GISP
Rickey's way of using !Important in the css will confine the widget to that top postion and make it unmovable up and down. What you really want to do is modify the opening position code in the widget See this thread:
https://community.esri.com/thread/190920-set-the-on-screen-widget-position-programmatically
CCWeedcontrol
Robert i add the following and it moved the context of the inside of the ESearch down (see attached).
  startup: function() {
        this.inherited(arguments);
        this._normalizePositionObj(this.position);
        this._makeOriginalBox();
        this.makePositionInfoBox();
        this.makeMoveable(this._positionInfoBox.w, this._positionInfoBox.w * 0.25);
        var position = {
          relativeTo: map,
          left: 277,
          top: 225,
          width: 300,
          height: 420
        this.getPanel().setPosition(position);
Not sure what all the other code is about but you only need this :
      startup: function(){
        var position = {
          relativeTo: map,
          left: 277,
          top: 225,
          width: 300,
          height: 420
        this.fetchData();
        this.list.parentWidget = this;
CCWeedcontrol
I replaced what i had previously( not sure what the other code was, i was already there.) with what you posted(lines 8-22) and nothing changed at start up.
postCreate: function() {
        this._originalBox = {
          w: 400,
          h: 410
        var position = {
          relativeTo: map,
          left: 277,
          top: 325,
          width: 300,
          height: 420
        this.fetchData();
      _onMaxBtnClicked: function(evt) {
        evt.stopPropagation();
        var posInfo = this._getPositionInfo();
        if (posInfo.isRunInMobile) {
          if (this.windowState === 'maximized') {
            this.panelManager.normalizePanel(this);
          } else {
            this.panelManager.maximizePanel(this);
          this._setMobilePosition();
Well I added that code to the eSearch widgets startup and it move the opening position as it should. So I am not sure what you are doing differently.
