Hi
Where can I modify the text content of WAB based app "Sign In" window? My focus is on the service (subfolder/service) and server (http://...) name, which I want to be removed (or hidden).
NLS libraries are not very helpful with those ![]()
Ramon,
This is what I figured out. In the jimu.js/tokenUtils.js find the _bindEvents and add lines 28-31 and add the new requires lines 18 - 20 and 23.
define([
'dojo/_base/lang',
'dojo/_base/array',
'dojo/aspect',
'dojo/Deferred',
'dojo/cookie',
'dojo/json',
'dojo/topic',
'dojo/request/script',
'esri/kernel',
'esri/config',
'esri/request',
'esri/urlUtils',
'esri/IdentityManager',
'esri/arcgis/OAuthInfo',
'jimu/portalUrlUtils',
'jimu/utils',
'dojo/on',
'dojo/dom-style',
'dojo/query'
function(lang, array, aspect, Deferred, cookie, json, topic, dojoScript, esriNS, esriConfig,
esriRequest, esriUrlUtils, IdentityManager, OAuthInfo, portalUrlUtils, jimuUtils, on, domStyle, query) {
_bindEvents: function(){
on(esriNS.id, 'dialog-create', function(){
domStyle.set(query(".serverLink", esriNS.id.dialog.domNode)[0], "display", "none");
domStyle.set(query(".resLink", esriNS.id.dialog.domNode)[0], "display", "none");
Ramon,
define([
'dojo/_base/lang',
'dojo/_base/array',
'dojo/aspect',
'dojo/Deferred',
'dojo/cookie',
'dojo/json',
'dojo/topic',
'esri/kernel',
'esri/config',
'esri/request',
'esri/urlUtils',
'jimu/utils',
'dojo/on',
'dojo/dom-style',
'dojo/query'
Works just the way I expected, thanks a lot ![]()
Oh, by the way Robert Scheitlin, GISP, do you have a clue where the rest of the sign in window text comes from. Trying to figure this out as this also looks kind of clumsy with my native language package
In english it is just one string, but in my case consists of three different strings.
Ramon,
Sure you need to change the default strings associated with the API and the dijit:
'dojo/i18n!esri/nls/jsapi',
esriBundle
esriBundle.identity.info = "Please sign in to access the item on ${server} ${resource}";Make sure you see this thread for info:
