After making some applications i noticed that the logo is always small how do you make logo bigger.
I would image you would have to move the header and the contents to the right. Can some one show me how to make these changes. please?
Are you using the default Launch pad theme style?
Thanks to both of you. I was able to make the logo bigger and move the zoom, home and locate icons down.
I just need to move and center the header with GIS app with Web Appbuilder for ArcGIS and the Esri world geocoder. How can move this?
edits i made,
.claro .jimu-widget-header .logo {
height: 115px !important;
width: 115px;
min-width: 50px;
background-color: #3b8fc4;
-webkit-border-radius: 50px;
border-radius: 80px !important;
position: relative;
top: -12px !important;
left: -1px !important;
-webkit-box-shadow: 0 1px 0.5px rgba(0,0,0,0.3), 0 2px 2px rgba(0,0,0,0.2);
Thanks.
Wow that is pretty large. I guess you are not concerned about mobile then.
You would have to adjust the top properties of the header and search widgets in the main config.json:
line 5 and 19 below:
"uri": "themes/LaunchpadTheme/widgets/Header/Widget",
"position": {
"left": 15,
"top": 37,
"width": 670,
"height": 46,
"relativeTo": "map"
"version": "2.3",
"id": "themes_LaunchpadTheme_widgets_Header_Widget_67",
"icon": "themes/LaunchpadTheme/widgets/Header/images/icon.png?wab_dv=2.1",
"name": "Header"
"uri": "widgets/Search/Widget",
"position": {
"left": 377,
"top": 45,
"width": 300,
"zIndex": 1,
"relativeTo": "map"
"version": "2.3",
"id": "widgets_Search_Widget_68",
"icon": "widgets/Search/images/icon.png?wab_dv=2.1",
"name": "Search"
Also you will need to adjust the top on line 9 too:
width: 115px;
min-width: 50px;
-webkit-border-radius: 80px;
position: relative;
top: -32px !important;
I was getting close but you pointed me to the answer, you are the MAN Robert!
Sorry to bug again but I am still a little off with the Esri World geocoder search. I tried adjusting the Widget Search but no luck, nothing changes. I must be missing something...
No matter what i change the "left" to nothing changes.
"position": {
"left": 660,
"top": 55,
"width": 300,
"zIndex": 1,
"relativeTo": "map"
"version": "2.3",
"id": "widgets_Search_Widget_38",
"name": "Search"
I did not try and change the left as that was not in your original question. It make be bound in the header widget code I have not checked that.
