License requirements
2435
11-14-2014 04:42 AM
AdamKuran
I want to ask 2 questions about licencsing WebApp Builder.
1. Do I need a Portal or arcgis.com licencse to use WAB - from licencse point of view? I know that is required from technical purposes.
2.WAB is licensed on Apache 2 license. Does it mean that I can use part of WAB application (stemapp) in my own application, i.e. take some widget and use it in my own application?
Looking forward info from you.
Adam
RobertScheitlin__GISP
Adam,
   An esri rep would have to answer definitively but you can assume that since the WAB StemApp uses the JavaScript API as the main source of it's code then what ever term of use bind you in using the JS API will apply to the Stem App. Terms and Conditions
