Label Pie Chart Infographic WAB 2.7
1515
02-01-2018 12:11 AM
MerrishaFrancis1
I have a pie chart infographic widget which I am using within the Dashboard theme. The pie chart represents the status of stock levels in a distribution warehouse:
  • Younger than 7 Days = 100
  • Between 7 and 10 Days = 20
  • Older than 10 Days = 80
Is there a way to customize the infographic widget such that the pie chart is labelled with the percentage of  each status? At the moment the only way to see those percentage values is by hovering over the chart and viewing the tooltip. However this dashboard is intended to be for display purposes only, users will not be able to interact with the chart to see the values.
Clairede_Berranger
We have the save need, and also, we need to see  the values and export what we see on board in a PDF file. Thank you
MarquesMunson1
Yes! I want to know the same thing!
