Issue with geoprocessing widget on Web App builder since June 2023 update
2981
6
06-21-2023 03:32 PM
explocarto
Hello,
We have implemented an application on AGOL which allows to download jpg files (January 2021).
https://georep-dtsi-sgt.opendata.arcgis.com/pages/e6c1a9aa45204255bc043eb40ac3a792
The application uses geoprocessing services (arcgis server) which compress files (jpg) + attachments.pdf and provide the download url of a zip.
https://carto.gouv.nc/public/rest/services/Explo_Carto/telechargement_grille_5_5_/GPServer
The process takes place without error, the zip file is indeed generated by the geoprocessing service, but it does not contain the files resulting from the selection (only attachments that we add when creating the zip). We have a message informing us that the selection is empty whereas 4 elements have been selected on the screen.
We feel like the 'Select Layer on Map' option in the AGOL Geoprocessing Widget no longer works as it did before the AGOL update.
We tried to reproduce the issue in a new app builder web application that uses the same geoprocessing service, and we also see an issue with the selection on the map.
The option 'Selection of a layer on the map' does not seem to work correctly because it returns all the elements of the selection layer (16 elements) and not just the selected elements (4 elements).
For your information, when we modify the configuration of the widget for a selection by a .shp and no longer on the map, the process works well and the zip created is correct.
Was the web app builder geoprocessing widget changed in the last AGOL update? (especially regarding the option 'Select a layer on the map')
Wei_Ying
Hi @explocarto ,
This issue has been fix today on AGOL production. Please let us know if the problem still occur to you.
explocarto
Hello @A_Wyn_Jones,
Kind regards
Pierre
explocarto
Hello @TanuHoque
Kind regards
Pierre
TanuHoque
looping in @Jianxia
Jianxia
@explocarto , thanks for letting us know. To help troubleshoot the issue, could you please contact Esri Support? cc to @TanuHoque
Wei_Ying
Hi @explocarto ,
explocarto
Thanks for the quick fix.
Our users thank you !
Kind regards
Pierre
