Is it possible to show widgets based on user login. show widgets which are authorized to users.
2088
09-07-2016 02:37 AM
Raghunatha_ReddySura
I like to show the widgets based on user login. to hide few widgets based on user login.
RobertScheitlin__GISP
See this thread (read all of the posts) for some help:
https://community.esri.com/thread/174605
Thanks  Robert.
Where  I can write this code, I mean on which js file. I need to validate this after opening the application. Is there is any common file available in WAB to write custom code that will execute after/before loading all widgets.
Raghunatha,
   If you are dealing with the map then jimu/MapManager.js If widget the jimu/WidgetMnager.js.
