Include 'TIME' with Date field for Popup works but nothing exists for Query Results?
6065
12
12-18-2015 09:27 AM
MichaelRobb
Honored Contributor
I have a question if this requires customizing or if I have missed a means of having this work out of the box.
Scenario
Web Map.  Configuring Popup, you can select to have Time included with Date field (Configuration)
As seen here:
The change would produce the following in a feature popup:
In the Web application Query widget... pointing to the same layer... If a Query is Initiated, the result as well as the Popup when clicking on the result shows the following:  (No Time)
Thoughts?
RobertScheitlin__GISP
Michael,
   I am just good a deciphering code, because I write code everyday.
MichaelRobb
Honored Contributor
Of course ESRI broke this in WAB 2.1  Back to only displaying a Date, without time.
Are you able to point me in the direction?
I have found the code block in Widgets\Query\SingleQueryLoader.js
but I cant get the time to appear in the query results or query result popup.
_tryLocaleDate: function(date){
var result = jimuUtils.localizeDate(date);
if(!result){
result = date.toLocaleDateString();
return result;
MichaelRobb
Honored Contributor
Looks like I had looked too deep into this...
this is now done through the config.json file.
e.g.
"fieldName": "CLOSE_TIME",
"label": "CLOSE_TIME",
"tooltip": "",
"visible": false,
"format": {
"dateFormat": "shortDateShortTime"
"stringFieldOption": "textbox"
