iFrame and in screen window
6967
23
08-29-2018 12:06 PM
joerodmey
Have a custom WAB app with a popup that provides a link for user to click on. This link brings them to a Survey123 form. Instead of opening up a new browser tab, I'm considering using the iFrame option to display the form in window.
Something like this:
map.infoWindow.setContent('<iframe  width="100%" height="1000"></iframe>');
Ideas welcomes.
Joe
joerodmey
Now I get the screen (below) even after reverting back to _blank. This occurs when I fire up WAB
RobertScheitlin__GISP
hmm... Have you tried clearing your browser cache?
joerodmey
Just tried that. Went to setup the portal page. Here I went thru the login process then it goes back to the error page as above.
joerodmey
Got it to work in Chrome.
Added the _parent and it opens in the same tab. Would there be a way to allow the user to get back to WAB from the Survey123 form?
only if you have the ability to add a link in your survey.
joerodmey
Ok
A note too my previous question. If I said that my WAB app is run on my own server but hosted on AGOL for the services and requires login. Does that change your viewpoint on iFrames? The users will be internal
Those are still two different domains no no that does not change the security issue.
joerodmey
What are your thoughts on something like this: xTF: Center a new popup window even on dualscreen with javascript
Joe,
   That is still opening a new window and just making it centered in the parent screens (but it is still a new window/tab).
joerodmey
Robert,
Just experimenting right now. Trying to implement the in screen popup (not iFrame) in MapManager.js but with little success.
Here is my code
function PopupCenter(url, title, w, h) {
    // Fixes dual-screen position                         Most browsers      Firefox
    var dualScreenLeft = window.screenLeft != undefined ? window.screenLeft : screen.left;
    var dualScreenTop = window.screenTop != undefined ? window.screenTop : screen.top;
    width = window.innerWidth ? window.innerWidth : document.documentElement.clientWidth ? document.documentElement.clientWidth : screen.width;
    height = window.innerHeight ? window.innerHeight : document.documentElement.clientHeight ? document.documentElement.clientHeight : screen.height;
    var left = ((width / 2) - (w / 2)) + dualScreenLeft;
    var top = ((height / 2) - (h / 2)) + dualScreenTop;
    var newWindow = window.open(url, title, 'scrollbars=yes, width=' + w + ', height=' + h + ', top=' + top + ', left=' + left);
    // Puts focus on the newWindow
    if (window.focus) {
        newWindow.focus();
  _publishMapEvent: function(map) {
        topic.subscribe('toggleChanged', lang.hitch(this, function(visible, layer){
          if(visible){
          // create node for the tooltip
          var tip = "Click on problem location";
          var tooltip = dojo.create("div", { "class": "tooltip", "innerHTML": tip }, map.container);
          dojo.style(tooltip, "position", "fixed");
          // update the tooltip as the mouse moves over the map
          dojo.connect(map, "onMouseMove", function(evt) {
            var px, py;
            if (evt.clientX || evt.pageY) {
              px = evt.clientX;
              py = evt.clientY;
            } else {
              px = evt.clientX + dojo.body().scrollLeft - dojo.body().clientLeft;
              py = evt.clientY + dojo.body().scrollTop - dojo.body().clientTop;
            // dojo.style(tooltip, "display", "none");
            tooltip.style.display = "none";
            dojo.style(tooltip, { left: (px + 15) + "px", top: (py) + "px" });
            // dojo.style(tooltip, "display", "");
            tooltip.style.display = "";
            // console.log("updated tooltip pos.");
          // hide the tooltip the cursor isn't over the map
          dojo.connect(map, "onMouseOut", function(evt){
        //add this property for debug purpose
        window._viewerMap = map;
        MapUrlParamsHandler.postProcessUrlParams(this.urlParams, map);
        console.timeEnd('Load Map');
        if (this.map) {
          this.map = map;
          this.resetInfoWindow(true);
          console.log('map changed.');
          topic.publish('mapChanged', this.map, this.layerInfosObj);
        } else {
          this.map = map;
          topic.publish('mapLoaded', this.map, this.layerInfosObj);
        require([
          'esri/graphic',
          'esri/symbols/SimpleMarkerSymbol',
          'esri/symbols/SimpleLineSymbol',
          'esri/Color'
        ], lang.hitch(this, function(Graphic, SimpleMarkerSymbol, SimpleLineSymbol, Color){
          var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_X, 18,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_X,
            new Color([207, 16, 45, 0.9]),
          map.on("click", lang.hitch(this, function(evt){
            var gra = new Graphic(evt.mapPoint, symbol);
            setTimeout(lang.hitch(this, function(){
              var selFeats = map.infoWindow.features;
              if(!selFeats){
                map.graphics.clear();
                map.graphics.add(gra);
          PopupCenter('http://www.xtf.dk','xtf','900','500');
                map.infoWindow.setContent('<a href="https://survey123.arcgis.com/share/xzy123?center='+ evt.mapPoint.getLatitude().toString() + ','+ evt.mapPoint.getLongitude().toString() + '" target="_blank"><font size="4">Click here to submit a service request</font></a>');
                map.infoWindow.show(evt.mapPoint);
            }), 1000);
