I created a custom widget and I need create a queryTask to a table in the map. But I can not use new QueryTask. How I can do it?
1035
05-29-2017 08:28 PM
andreacarina
define([
'dojo/_base/declare',
'jimu/BaseFeatureAction',
'jimu/WidgetManager',
'esri/tasks/query',
'esri/tasks/QueryTask'
], function(declare, BaseFeatureAction, WidgetManager){
var clazz = declare(BaseFeatureAction, {
iconFormat: 'png',
isFeatureSupported: function(featureSet){
return featureSet.features.length == 1 && featureSet.features[0].attributes.state_name != undefined && featureSet.features[0].attributes.state_name == 'Montana';
onExecute: function(featureSet){
WidgetManager.getInstance().triggerWidgetOpen(this.widgetId)
.then(function(myWidget) {
var queryTask = new QueryTask("http://services2.arcgis.com/zjX47EEgMzOqxwh7/ArcGIS/rest/services/Mapa/FeatureServer/1");
var query = new Query();
query.returnGeometry = false;
query.outFields = [
"Bocas"
query.text = "EquipoId = 'Eq1'";
queryTask.execute(query, showResults);
function showResults(results) {
var resultItems = [];
var resultCount = results.features.length;
myWidget.ViewImage(resultCount);
return clazz;
KenBuja
You have to add in the arguments in the function to tell the code what QueryTask and Query are. If you examine the console, you should see errors indicating this.
