https Portal Login
8272
10
08-13-2014 07:28 AM
JoshuaDell1
I am trying to log into my organization's portal from Web AppBuilder.  We have our portal site secured and is only accessible HTTPS://.  In Web AppBuilder when I attempt to login to our portal https://, then press continue, the "S" gets stripped out of https.  I just get an error message: "Unable to access http://<;purtal url> A server with the specified hostname could not be found".  Has anyone found a workaround for this?
Josh
RobertScheitlin__GISP
Joshua,
  Go to the client\stemapp\jimu.js\dijit\SetPortalUrl.js and on line 177 (assuming you are talking about Beta 2) comment that line out:
// change https to http
url = PortalUrlUtils.setHttpProtocol(url);
I am not sure if that is it but by looking at the code, it is a good place to start.
MauraTokay
Hi Robert,
I am getting the same error but I don't use https. Do you have any idea how I can troubleshoot this problem?
Maura
Maura,
   Can you closely check the url that it is complaining about to see if there is some typo or reason it would not resolve. If you are not using a https portal url or an on premise portal url than I don't know of a reason it would be getting that error.
JoshuaDell1
Thanks pointing me in the right direction Robert.
I commented line 177
and changed line 167 from,
var standardUrl = PortalUrlUtils.setHttpProtocol(this.portalUrlInput.get('value'));
to.
var standardUrl = this.portalUrlInput.get('value');
I was able to get to the sign in page, but now when attempting to sing in I get an error:
"Incorrect username or password"
and I am seeing this error in chrome developer tools:
Failed to load resource: net::ERR_CONNECTION_REFUSED... http://<machine name>/proxy.js?https<my portal url>/arcgis/sharing/generateToken
Joshua,
   There might be more to the not using https then it appears then... Have you logged a bug in the Beta program site?
Noah-Sager
I've seen some similar issues like this in the Beta community. Two things I would verify:
1) Make sure Portal is using built-in security (not Windows security or PKI security as these will not work per the doc)
2) Make sure the relevant SSL certificates and trusted domains are installed/configured in the browser
Hope this helps.
-Noah
BillLotz
I am having the same issue as well. I was told to temporarily  try unchecking "Allow access to the organization through SSL only." in our AOL site but it still generates an error.
BillLotz
Interesting enough, at the screen after I enter the path to AGOL, where it asks for my username and password, if I enter an incorrect password it knows it. I enter correct password and it just kicks back to "Unable to access ..." screen.
Fiddler shows that the app is communicating in my AGOL page, it comes back with all the details. How can the Server not be found???
Any Ideas?
deleted-user-YYhuCJuuEn9L
For me, the problem seemed to be related to certificates. The Web AppBuilder tries to access the sharing/generateToken end point of the portal over SSL which in my case was throwing an ERR_INSECURE_RESPONSE error in Chrome. I right-clicked the requests in the Network tab of the developer tools window to open in a new tab. I followed the links to proceed to the insecure content. I was then able to go back and login.
