HTML elements not showing
2686
08-08-2019 12:25 PM
BrianLeroux
I started createing anew widget. First I wanted to lay our all the fields I wanted on the panel. I have 16 fields and 1 button. When I load the widget I only see some of the elements in the widget. When I load on different browsers I still get only some of the elements but sometimes not the same ones.When I check the web response widgets/ClaimsAnalysisPanel/Widget.html?wab_dv=2.11 it has all the elements that I need in the text but looking at the debugger preview screen it only shows some of them. I am stumped. Any ideas?
<div>
<label for="capFromDate">Loss Date From: </label>
 <input type="text" name="capFromDate" id="capFromDate" value="now" data-dojo-type="dijit/form/DateTextBox"
 required="false" constraints="{min:'2008-01-01'}" /><br>
<label for="capToDate">Loss Date To: </label>
 <input type="text" name="capToDate" id="capToDate" value="now" data-dojo-type="dijit/form/DateTextBox"
<label for="capRptFromDate">Reported Date From: </label>
 <input type="text" name="capRptFromDate" id="capRptFromDate" value="now" data-dojo-type="dijit/form/DateTextBox"
<label for="capRptToDate">Reported Date To: </label>
 <input type="text" name="capRptToDate" id="capRptToDate" value="now" data-dojo-type="dijit/form/DateTextBox"
<label for="capperil">Peril: </label>
 <select name="capperil" id="capperil" data-dojo-type="dijit/form/Select" required="false" /><br>
<label for="capcat">Cat Code: </label>
 <select name="capcat" id="capcat" data-dojo-type="dijit/form/Select" required="false" data-dojo-attach-event="onChange:capcatChanged" /><br>
<label for="capbranch">Branch: </label>
 <select name="capbranch" id="capbranch" data-dojo-type="dijit/form/Select" required="false" /><br>
<label for="caphandler">Handler: </label>
 <select name="caphandler" id="caphandler" data-dojo-type="dijit/form/Select" required="false" /><br>
<label for="capia">IA: </label>
 <select name="capia" id="capia" data-dojo-type="dijit/form/Select" required="false" /><br>
<label for="capstate">State: </label>
 <select name="capstate" id="capstate" data-dojo-type="dijit/form/Select" required="false" /><br>
<label for="capcounty">County: </label>
 <select name="capcounty" id="capcounty" data-dojo-type="dijit/form/Select" required="false" /><br>
<label for="capzip">Zip: </label>
 <select name="capzip" id="capzip" data-dojo-type="dijit/form/TextBox" required="false" /><br>
<label for="capcovAFrom">Cov A Paid From: </label>
 <input type="text" name="capcovAFrom" id="capcovAFrom" data-dojo-type="dijit/form/CurrencyTextBox" required="false"
 data-dojo-props="constraints:{fractional:true}, currency:'USD', invalidMessage:'Invalid amount. Cents are required.'" /><br>
<label for="capcovATo">Cov A Paid To: </label>
 <input type="text" name="capcovATo" id="capcovATo" data-dojo-type="dijit/form/CurrencyTextBox" required="false"
<label for="capPolicyForm">Policy Form: </label>
 <select name="capPolicyForm" id="capPolicyForm" data-dojo-type="dijit/form/Select" required="false" /><br>
<label for="capStatus">Status: </label>
 <select name="capStatus" id="capStatus" data-dojo-type="dijit/form/Select" required="false" /><br>
<div class="jimu-btn" data-dojo-attach-point="btnRun" data-dojo-attach-event="onclick:loadbtnClick">Load</div>
</div>
RobertScheitlin__GISP
Brain,
  Change all your selects to be like this:
<select name="capPolicyForm" id="capPolicyForm" data-dojo-type="dijit/form/Select" required="false"></select><br>
Brain,
   Based on your attached image none of your data-dojo-types are being rendered/recognized. It looks like you have failed to use "_WidgetsInTemplateMixin"
https://developers.arcgis.com/web-appbuilder/guide/use-dojo-dijit.htm
BrianLeroux
That image is how it renders in the Chrome debugger. I just wanted to show that even in there it is not loading all the elements. Here is how it looks in the widget. It is just missing some of the html elements.
I am using _WidgetsInTemplateMixin as seen below.
define(['dojo/_base/declare',
 'jimu/BaseWidget',
 "esri/request",
 'dojo/_base/json',
 'dojo/_base/array',
 'dojo/date',
 'dijit/form/DateTextBox',
 "dijit/form/Select",
 "dijit/form/MultiSelect",
 "dijit/form/FilteringSelect",
 "dijit/form/CurrencyTextBox",
 "dojo/store/Memory",
 "dojo/data/ObjectStore",
 "dijit/registry",
 'dijit/_WidgetsInTemplateMixin'],
 function(declare, BaseWidget, esriRequest, JSON, array, date, DateTextBox, Select, MultiSelect, FilteringSelect, CurrencyTextBox, Memory, ObjectStore, registry, _WidgetsInTemplateMixin) {
 //To create a widget, you need to derive from BaseWidget.
 return declare([BaseWidget, _WidgetsInTemplateMixin], {
 // Custom widget code goes here
 baseClass: 'jimu-widget-claimsanalysispanel',
Brain,
BrianLeroux
That did the trick. Thank you.
Now to find out why my multiselect with not populate when connecting to a store.
