How to update from WAB Developer Edition 2.2 to 2.7?
7625
13
01-22-2018 03:01 PM
EmilioSolano
Would like instructions to update from Web Appbuilder Developer Edition 2.2 to the new 2.7 version. I haven't found any instructions, only the steps to install from scratch.
My concern is to upgrade without having to damage existing custom widgets.
Thanks.
RobertScheitlin__GISP
Matthew,
   Sorry I have not seen that before. You need to contact esri tech support.
Cook_CountyGIS
Devon, did you end up successfully upgrading from 2.4 to 2.7 or did you step through the consecutive versions to get there?
DevonHedemark1
We have not yet.  I will probably just stand-up a new app and use the same web maps.  Then, configure a couple widgets.  The upgrade process seems a bit convoluted.
Regards, Devon
JamesMadden1
I'm upgrading my WAB apps from 2.19 to 2.25 and I've noticed that customizations to CSS classes are not maintained and the upgrade drops changes I've made to the PopupManager.js file.  Additionally, settings defined in our web.config file are not copied over.  Is this normal behavior in the upgrade process or should those changes be maintained during the upgrade?  I upgraded all apps at once.  I may try to upgrade the apps one at a time but I expect the behavior to be the same.
