Back in the glory days of the Flex viewer it was possible to load a URL parameter for separate configs from a URL, eg:
index.html?config=rivers.xml
index.html?config=roads.xml
etc
Is it possible to load separate config.json files through a URL parameter as a similar approach for WAB Developer Edition? Or can this be embedded in the basic index.html as a similar method?
I have about 10 applications where the config is largely the same but some widget configs are not identical. So this approach would allow me to use a simple parameter to link to different configs and ultimately different widget settings.
Thanks a lot,
Brendan
