How to include a link on the WAB icon
5283
01-27-2015 08:45 PM
StephenLead
Honored Contributor
In the Attributes section of an application, you can set the app's icon. You can also add a link - this is placed to the right of the subtitle text:
How can I add a link to the icon itself, so that clicking on the three coloured blocks navigates somewhere?
The icon seems to be loaded dynamically, into this div:
<div class="header-section jimu-float-leading" data-dojo-attach-point="headerNode">
    <img class="logo jimu-float-leading jimu-leading-margin1" data-dojo-attach-point="logoNode" src="images\logo.png" style="height: 30px; min-width: 30px; margin-top: 5px; cursor: default;">
</div>
Which script builds this section of the UI? It should be possible to wrap the whole thing in an <a href> tag.
thanks,
Steve
StephenLead
Honored Contributor
Some digging shows that the script which builds the header, including the logo, is found at \themes\<theme name>\widgets\HeaderController\Widget.js.
These edits seem to do the trick
- edit the application's main config.js file to include a new property logoLink:
"logoLink": "http://www.google.com.au",
- add this to the \themes\<theme name>\widgets\HeaderController\Widget.js script around line 92:
html.setAttr(
  this.logoLink,
  'href',
  this.appConfig.logoLink ? this.appConfig.logoLink : "#"
- add the template <a> code into  \themes\<theme name>\widgets\HeaderController\Widget.html around the logo image:
<a data-dojo-attach-point="logoLink">
  <img class="logo jimu-float-leading jimu-leading-margin1" data-dojo-attach-point="logoNode">
</a>
It would be nice if someone could explain how to build the logoLink property from the main UI, rather than needing to hack into the config.js file manually.
StephenLead
Honored Contributor
html.setAttr(
  this.logoLink,
  'href',
</a>
JasonStanton__GISP
How do i get this to open in a new tab, and is it possible to add a tooltip?
