How to implement own script to aplication built by WAB
7016
13
11-30-2015 08:48 AM
LadislavRozkosny
I have script to clustering with tutorial, how to implement to Arcgis api for javascriot. But i need implement this to app. Apps from WAB are consist of several files and I don't know where i must write a peace of code. In classical API this is simple, but when i have app, i have file f.e. index.html, env.js, simpleLoader.js and int.js.
RobertScheitlin__GISP
Ladislav,
   You are out of luck then as the available options do not suit your desires.
LadislavRozkosny
First script http://www.arcgis.com/home/item.html?id=c546bc8d4f0b4c0fbdf149b92223e681 is difficult change for latest version API?
Ladisav,
   That code is over 5 years old. With you limited coding experience you are just going to have to settle for what is available.
LadislavRozkosny
It's very bad situation for me. 😕 I'm going to try solve change app and implement japan widget.
