How to filter features on map in Web AppBuilder?
14246
23
07-30-2015 04:06 PM
EmilyLee
I'm trying to use the filter function from the layer table in the Web AppBuilder as we would use the definition query in ArcMap.  But in the Web AppBuilder, it wouldn't hide the unwanted features.  It'd just filter them out in the layer table, but no effect on the map at all and still showing everything.
So, I tried to use the Query widget, it'd just highlight the filtered features, but still not hiding the unwanted features on map.  The "Use spatial filter to limit features" box doesn't do anything.  Is it a bug?  Or am I doing something wrong or misunderstood something here?
Thank you for your help,
Emily
RobertScheitlin__GISP
Ikbel,
   The filter widget in WAB does filter features on the map based on the filter expression. For opening the Attribute Table widget automatically you can follow this guide:
Send a layer to the Attribute Table widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS fo...
ikbelkachbouri
Hi Robert ,
I want to show the filter widget result in the map (Selection ) (draw result) .
Ikbel,
   Maybe you are not understanding. The filter widget DOES show the results on the map.
ikbelkachbouri
Just the Zoom but there is no result layer or selection in the map .
Ikbel,
   Then you are not using the filter widget correctly.
Filter widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
ikbelkachbouri
Hi Robert ,
Can you help me to modify this code in order to show filter widget results in attribute tabe automatically .
Widget.js
// Copyright © 2014 - 2017 Esri. All Rights Reserved.
// Licensed under the Apache License Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
define([
'dojo/_base/declare',
'dojo/_base/array',
'dojo/_base/html',
'dojo/_base/lang',
'dojo/query',
'dojo/on',
'dijit/_WidgetsInTemplateMixin',
'jimu/utils',
'jimu/BaseWidget',
'jimu/filterUtils',
'jimu/dijit/FilterParameters',
'jimu/LayerInfos/LayerInfos',
'jimu/FilterManager',
'esri/request',
'esri/tasks/query',
'esri/tasks/QueryTask',
'jimu/dijit/LayerChooserFromMapWithDropbox',
'jimu/dijit/Filter',
'./CustomFeaturelayerChooserFromMap',
'jimu/dijit/ToggleButton',
'dojo/NodeList',
'dojo/NodeList-dom'
function(declare, array, html, lang, query, on, _WidgetsInTemplateMixin,
jimuUtils, BaseWidget, FilterUtils, FilterParameters,LayerInfos,FilterManager,
esriRequest, Query, QueryTask, LayerChooserFromMapWithDropbox, Filter, CustomFeaturelayerChooserFromMap, ToggleButton) {
return declare([BaseWidget, _WidgetsInTemplateMixin], {
baseClass: 'jimu-widget-filter',
//style="display:${hasValue}"
_itemTemplate: '<li class="filter-item" data-index="${index}">' +
'<div class="header" >' +
'<span class="arrow jimu-float-leading jimu-trailing-margin05" title="${toggleTip}" ></span>' +
'<span class="icon">' +
'<img src="${icon}" />' +
'</span>' +
'<span class="item-title">${title}</span>' +
'<span class="toggle-filter jimu-trailing-margin1"></span>' +
'</div>' +
'<div class="body">' +
'<div class="parameters"></div>' +
'</div>' +
'</li>',
_store: null,
postMixInProperties:function(){
this.jimuNls = window.jimuNls;
postCreate: function(){
this.inherited(arguments);
this._store = {};
this.layerInfosObj = LayerInfos.getInstanceSync();
this.filterUtils = new FilterUtils();
this.filterManager = FilterManager.getInstance();
if(this.config.allowCustom){
html.setStyle(this.showCustomButtonNode, 'display', 'block');
var existAskForValue = false;
var filters = this.config.filters;
array.forEach(filters, function(filterObj, idx) {
var isAskForValue = this.filterUtils.isAskForValues(filterObj.filter);
if(isAskForValue){
existAskForValue = true;
var parse = {
icon: filterObj.icon ? jimuUtils.processUrlInWidgetConfig(filterObj.icon, this.folderUrl) :
this.folderUrl + '/css/images/default_task_icon.png',
index: idx,
title: filterObj.name,
toggleTip: this.nls.toggleTip,
hasValue: isAskForValue ?
(window.appInfo.isRunInMobile ? 'block !important' : '') : 'none',
isAskForValue: isAskForValue,
apply: lang.getObject('jimuNls.common.apply', false, window) || 'Apply'
if (!this._store[filterObj.layerId]) {
this._store[filterObj.layerId] = {
mapFilterControls: {}
// filter_item_idx
}; // filter_item_idx, mapFilterControls
var template = lang.replace(this._itemTemplate, parse, /\$\{([^\}]+)\}/ig);
var node = html.toDom(template);
html.place(node, this.filterList);
var toggleButton = new ToggleButton({}, query('.toggle-filter', node)[0]);
toggleButton.startup();
node.toggleButton = toggleButton;
this.own(
query('.header', node)
.on('click', lang.hitch(this, 'toggleFilter', node, filterObj, parse))
if(isAskForValue){
html.addClass(node, 'has-ask-for-value');
}else{
html.addClass(node, 'not-has-ask-for-value');
if (parse.hasValue !== 'none') {
// add parameters
this.own(
query('.arrow', node)
.on('click', lang.hitch(this, 'configFilter', node, filterObj))
html.addClass(node, 'requesting');
this.configFilter(node, filterObj, null, lang.hitch(this, function(){
if(filterObj.collapse){
html.removeClass(node, 'config-parameters');
if(filterObj.autoApplyWhenWidgetOpen){
this.toggleFilter(node, filterObj, parse);
}else{
}, this);
if(!existAskForValue){
html.addClass(this.domNode, 'not-exist-ask-for-value');
startup: function() {
this.resize();
_getPriorityOfMapFilter: function(layerId) {
var mapFilterControls = lang.getObject(layerId + '.mapFilterControls', false, this._store);
var count = 0;
for (var p in mapFilterControls) {
var control = mapFilterControls
if (control.priority > count) {
count = control.priority;
return count;
_getMapFilterControl: function(layerId) {
var count = 0;
var enable = true;
enable = !!control.enable;
return enable;
_setItemFilter: function(layerId, idx, expr, enableMapFilter) {
this._store[layerId]['filter_item_' + idx] = expr;
var priority = this._getPriorityOfMapFilter(layerId);
lang.setObject(layerId + '.mapFilterControls.filter_item_' + idx , {
enable: enableMapFilter,
priority: priority + 1
}, this._store);
_removeItemFilter: function(layerId, idx) {
delete this._store[layerId]['filter_item_' + idx];
delete this._store[layerId].mapFilterControls['filter_item_' + idx];
_getExpr: function(layerId) {
if (!this._store[layerId]) {
return null;
var parts = [];
var exprs = this._store[layerId];
for (var p in exprs) {
var expr = exprs
if (expr && p !== 'mapFilterControls') {
parts.push('(' + expr + ')');
return parts.join(' AND ');
toggleFilter: function(node, filterObj, parse) {
if (html.hasClass(node, 'config-parameters') &&
!(node.filterParams && node.filterParams.getFilterExpr())) {
return;
if (parse.isAskForValue && !(node.filterParams && node.filterParams.getFilterExpr())) {
this.configFilter(node, filterObj);
return;
// if(node.toggleButton.isDoing){
// return;
var layerId = filterObj.layerId;
var idx = html.getAttr(node, 'data-index');
var layerFilterExpr = null;
var applied = html.hasClass(node, 'applied');
if (applied) {
html.removeClass(node, 'applied');
node.toggleButton.uncheck();
} else {
html.addClass(node, 'applied');
node.toggleButton.check();
var enableMapFilter = null;
if (!applied) {
var expr = this._getFilterExpr(node, filterObj);
this._setItemFilter(layerId, idx, expr, filterObj.enableMapFilter);
layerFilterExpr = this._getExpr(layerId);
enableMapFilter = this._getMapFilterControl(layerId);
this.filterManager.applyWidgetFilter(layerId, this.id, layerFilterExpr, enableMapFilter);
} else {
this._removeItemFilter(layerId, idx);
this._afterFilterApplied(filterObj.layerId);
configFilter: function(node, filterObj, evt, cb) {
if (!node.filterParams) {
esriRequest({
url: filterObj.url,
content: {
f: 'json'
handleAs: 'json',
callbackPrams: 'callback'
}).then(lang.hitch(this, function(definition) {
html.addClass(node, 'config-parameters');
html.removeClass(node, 'requesting');
var pamDiv = query('.parameters', node)[0];
node.handles = [];
node.filterParams = new FilterParameters();
var partsObj = lang.clone(filterObj.filter);
var layerId = null;
if(filterObj.enableMapFilter){
//if enableMapFilter is true, pass layerId to filterParams,
//so filterParams can get the layer expr defined in webmap
node.filterParams.build(filterObj.url, definition, partsObj, layerId);
this.own(on(node.filterParams, 'change', lang.hitch(this, function(expr) {
if (expr) {
node.expr = expr;
} else {
delete node.expr;
if(node.toggleButton.checked){
this.applyFilterValues(node, filterObj);
node.expr = node.filterParams.getFilterExpr();
node.filterParams.placeAt(pamDiv);
this._changeItemTitleWidth(node, 60);
if(cb){
cb();
} else {
if (!html.hasClass(node, 'config-parameters')) {
} else {
this._changeItemTitleWidth(node, window.appInfo.isRunInMobile ? 60 : 45);
if(cb){
cb();
if (evt && evt.target) {
evt.stopPropagation();
applyFilterValues: function(node, filterObj, evt) {
if (expr) {
node.expr = expr;
// getFilterExpr
this._setItemFilter(layerId, idx, node.expr, filterObj.enableMapFilter);
var layerFilterExpr = this._getExpr(layerId);
var enableMapFilter = this._getMapFilterControl(layerId);
if(evt){
_getFilterExpr: function(node, filterObj){
if(node.filterParams){
return node.filterParams.getFilterExpr();
if(this.filterUtils.hasVirtualDate(filterObj.filter)){
this.filterUtils.isHosted = jimuUtils.isHostedService(filterObj.url);
return this.filterUtils.getExprByFilterObj(filterObj.filter);
}else{
return filterObj.filter.expr;
_afterFilterApplied: function(layerId){
if(!this.config.zoomto){
return;
var layerInfo = this.layerInfosObj.getLayerInfoById(layerId);
if(!layerInfo){
return;
var query = new Query();
query.where = layerInfo.getFilter()? layerInfo.getFilter(): '1=1';
query.returnGeometry = true;
query.outSpatialReference = this.map.spatialReference;
var qryTask = new QueryTask(layerInfo.getUrl());
//query extent only firstly
qryTask.executeForExtent(query, lang.hitch(this, function(result){
if(result.extent && this._isValidExtent(result.extent)){
this.map.setExtent(result.extent);
return;
//some services don't support query extent, do feature query.
qryTask.execute(query).then(lang.hitch(this, function(featureSet){
jimuUtils.featureAction.zoomTo(this.map, featureSet.features);
_isValidExtent: function(extent){
return !(isNaN(extent.xmax) || isNaN(extent.xmax) ||
isNaN(extent.xmax) || isNaN(extent.xmax));
resize: function() {
this._changeItemTitleWidth(this.domNode, window.appInfo.isRunInMobile ? 60 : 45);
if(this.customFilter){
this.customFilter.resize();
_changeItemTitleWidth: function(node, tolerace) {
tolerace += 30;
var itemHeader = query('.header', node)[0];
if (itemHeader) {
var contentBox = html.getContentBox(itemHeader);
var maxWidth = contentBox.w - tolerace;// width of header minus others width
if (maxWidth > 0) {
query('.header .item-title', node).style({
'maxWidth': maxWidth + 'px'
_onShowCustomClick: function(){
html.setStyle(this.customFilterContainerNode, 'display', 'block');
html.setStyle(this.filterListContainerNode, 'display', 'none');
if(!this.layerChooserSelect){
var layerChooser = new CustomFeaturelayerChooserFromMap({
showLayerFromFeatureSet: false,
showTable: false,
onlyShowVisible: false,
createMapResponse: this.map.webMapResponse
this.layerChooserSelect = new LayerChooserFromMapWithDropbox({
layerChooser: layerChooser
this.layerChooserSelect.placeAt(this.layerSelectNode);
this.own(on(this.layerChooserSelect, 'selection-change', lang.hitch(this, this._onLayerChanged)));
this.layerChooserSelect.showLayerChooser();
_onLayerChanged: function(){
var item = this.layerChooserSelect.getSelectedItem();
if(!item){
return;
//nameTextBox
var layerInfo = item.layerInfo;
var layer = layerInfo.layerObject;
//filter
var layerDefinition = this._getLayerDefinitionForFilterDijit(layer);
if(!this.customFilter){
this.customFilter = new Filter({
enableAskForValues: false,
featureLayerId: layer.id
this.customFilter.placeAt(this.customFilterNode);
this.own(on(this.customFilter, 'change', lang.hitch(this, this._onCustomFilterChange)));
this.customFilter.build({
url: layer.url,
layerDefinition: layerDefinition
this.selectedLayer = layer;
_getLayerDefinitionForFilterDijit: function(layer){
var layerDefinition = null;
if(layer.declaredClass === 'esri.layers.FeatureLayer'){
layerDefinition = jimuUtils.getFeatureLayerDefinition(layer);
if (!layerDefinition) {
layerDefinition = {
currentVersion: layer.currentVersion,
fields: lang.clone(layer.fields)
return layerDefinition;
_onBackToListClick: function(){
html.setStyle(this.customFilterContainerNode, 'display', 'none');
html.setStyle(this.filterListContainerNode, 'display', 'block');
_onCustomFilterToggle: function(isChecked){
return;
if(!isChecked){
this.filterManager.applyWidgetFilter(this.selectedLayer.id, this.id + '-custom-filter', '1=1', true);
this._afterFilterApplied(this.selectedLayer.id);
}else{
this._applyCustomFilter();
_onCustomFilterChange: function(){
_applyCustomFilter: function(){
var filterJson = this.customFilter.toJson();
if(!filterJson || !this.customFilterToggleButton.checked || filterJson.parts.length === 0){
return;
this.filterManager.applyWidgetFilter(this.selectedLayer.id, this.id + '-custom-filter', filterJson.expr, true);
destroy: function(){
query('.filter-item', this.filterList).forEach(function(node) {
delete node.filterParams;
delete node.expr;
if (this._store) {
for (var p in this._store) {
if (p) {
this.filterManager.applyWidgetFilter(p, this.id, "", null);
ikbelkachbouri
Thank you so much Robert . The filter widget query results is opened automatically in attribute table .
ikbelkachbouri
ikbelkachbouri
Hi Robert ,
this is a link to my filter widget . There is just the zoom after applying the filter .I want to draw result in the map (Selection ) like in query and create  feature result in legend and layer list . thank you for your help .
ikbelkachbouri
Hi Robert ,
ArcGIS Web Application
