How to configure default "Attribute Table" widget on Foldable Theme?
2444
5
01-31-2020 12:58 PM
chintakandel
"Attribute Table" widget displays all the layer from layer list on Foldable Theme. Some of my layers do not support query operation to display in Attribute Table widget. How can I remove layers from "Attribute Table" widget that do not support query operation?
Thanks in advance,
Chintamani
RobertScheitlin__GISP
Have you open the attribute table widgets setting dialog and remove those layers?
chintakandel
Hi Robert,
I could not find Attribute Table widget in Widget Tab drop down list in builder (2.15). I did not add it. It appears by default (as off-panel widget) in Foldable Themes but could not find it to open and configure.
Chintamani
chintakandel
Thank you Robert. Attribute table widget is not available to add in Header controller widget. Attribute table widget appears at the bottom by default in Foldable Theme. I could not access it configure.
You can not choose where to add the Attribute Table widget. In the foldable theme it is added by default and you configure it by clicking on the pencil icon as I have shown in the screen shot I last posted.
