How do you uninstall Web AppBuilder?
4293
08-19-2015 08:40 AM
ChrisSergent
I have seen all of the information on how to install Web AppBuilder, but how do you uninstall it? Is there a step by step process for that as well?
Tags (1)
RobertScheitlin__GISP
Chris,
     Most people are not actually following the getting started guide and are not installing NodeJS on their machines. So if you are one of those then all you need to do is delete the folder you downloaded the WAB Dev to. If you did install NodeJS then you will also need to go to the add/remove programs and uninstall NodeJS.
Chris,
ChrisSergent
I uniststalled NodeJS already. So it looks like I just need to delete some folders. Thanks.
