How can i view the multidimensional filter feature availble for raster dataset in webapp builder?
1796
11-19-2021 04:57 AM
RehanChaudhary
I am trying to create a web app for a multidimensional raster dataset. I have created a web map to be used in this web app from this data set . The data set was converted into a CRF to be pusblished as an imagery layer The web map contains the  CRF and through this i can switch between different variables available within the dataset using the multidimensional filter.
My question is that is there a possibility that i can make this feature available somewhere in my app so that user can switch the variables and view the map and related data for it?
DougBrowning
MVP Esteemed Contributor
Every figure this out?  Works in Map Viewer Classic but not seeing it in WAB?
RehanChaudhary
nope. the alternate solution i did was to cerate individual layers for each variable and then switch through the layer list.
