How can I use the map layer's popup results when clicking on a result in the Query Widget?
1639
12-12-2019 09:36 AM
AndyWells
In the Query widget, when you perform a search and are returned a list of search results you can click on a result and normally the map will pan to that location and you will get the popup that is configured in the Query widget. Instead of using that, I would really like to use the popup that is configured in the webmap for the particular layer that I am performing searches on. Is there a way to do that? I have seen some similar questions here, but I can't quite figure out what, if anything, can be edited to allow this behavior.
Thanks!
RobertScheitlin__GISP
Andy,
   As you can see in the attached image the use of the configured popup in the web map for a layer is an option in the widgets settings.
AndyWells
Robert
I realized that I wasn't clear in the question, and that I may have caused the issue when I made some changes to the Query's widget.js to keep it from showing both the search results pop-up AND the map pop-up if you click on the result on the map. I commented out "resultLayer.setInfoTemplate(popupTemplate);" in Query/Widget.js and it's likely that is exactly the same pop-up that I actually want to see when you click the search result in the query widget. However, even when I un-comment that line, I am only able to get
What I get when I click the search results (with "resultLayer.setInfoTemplate(popupTemplate)" commented out") is this:
What I want it to do is this:
I want to use the map's configured pop-up in the pop-up panel, with an abbreviated set of attributes showing in the search results list.
Any other tidbits of information you may have, I'd be happy to hear!
Thank you
Andy
Andy,
   Has to be something you have done in your changes to the query widget then. When I configure the Popup panel and the query widget to show the webmaps popups it work fine.
