How can I disable visibility of a group layer???
8315
14
08-22-2014 05:49 AM
ErikLima
Hi!!!
I have a problem with group layer on widget LayerList... disable visibility (checkbox) of the layers don't work, neither when I unckeck the group layer that contain the layers that I have disable visibility...
Somebody had this problem?? How can I resolve it???
RobertScheitlin__GISP
Get Beta 3 and just copy your config.json and your widget *.json files into a new Beta 3 App that you build. Unless you have done some actually changes to the stem apps javascript files (the coding files, not just configuration changes), then just moving your configuration changes to a new app will not be hard at all.
ErikLima
Robert,
I have much changes and customizations in many widgets, so in this case the effort is very high...
I was trying to force the toggle of visibility "manually" in the event click. In this event I have the layerInfo of the layer that I want manipulate the visibility. How can I set your visibility only getting the layerInfo?
Or have an other function that put the ID of my MapService and it do this?
Thanks!
Erik,
   It was a poor decision to invest that much time in making code changes to a Beta 1. Beta 3 does not have the issue you are speaking of so my advice is to try and find what has changed  (a emitted event name change or something) between Beta1 and beyond.
ErikLima
Ok, Robert!
I will go try do it!!
Thanks again!!!
ErikLima
Hi, people!
Problem resolved!
How I already had replaced the widget Beta 1 by Beta 2, I discovered that a array was being created wrong, including the indexs of groups. So I manipulated this array to remove all index of all groups before send to toggle the visibility.
This array is manipulated in ...\jimu.js\LayerInfos\LayerInfoForMapService.js, the method is "setSubLayerVisible". Follows the code of my solution:
   // Gets the correspondent layer info
   getLayerInfo: function(layerInfos, id) {
      var layerInfo = null;
      for (var i = 0; layerInfos.length; i++) {
        if (layerInfos.id == id) {
          layerInfo = layerInfos;
          break;
      return layerInfo;
    // Removes all indexs of all groups
    clearVisibleLayers: function(visibleLayers, layerInfos) {
      var myVisibleLayers = lang.clone(visibleLayers);
      var myLayerInfos = layerInfos;
      array.forEach(visibleLayers, lang.hitch(this, function(idVisibleLayer){
        layerInfo = this.getLayerInfo(myLayerInfos, idVisibleLayer)
        if (layerInfo && layerInfo.subLayerIds != null) {
          var index = array.indexOf(myVisibleLayers, idVisibleLayer);
          myVisibleLayers.splice(index, 1);
      }), this);
      return myVisibleLayers;
    setSubLayerVisible: function(subLayerId, visible) {
      var ary = [],
        index;
      if (subLayerId !== null) {
        // Here is the alteration
        ary = lang.clone(this.originOperLayer.layerObject.visibleLayers);
        ary = this.clearVisibleLayers(ary, this.originOperLayer.layerObject.layerInfos);
        index = array.indexOf(ary, subLayerId);
        if (visible) {
          if (index < 0) {
            ary.push(subLayerId);
            this.originOperLayer.layerObject.setVisibleLayers(ary);
        } else {
          if (index >= 0) {
            ary.splice(index, 1);
          if (ary.length === 0) {
            ary.push(-1);
