How Can I add a custom logo and a text to a standard print A3 A4 Print Layout?
813
04-26-2019 06:46 AM
NatashaManzuiga
Hi all,
I just need to add a custom text and a logo to my print layout A3/A4 Landscape/Portrait.
Is it possible? If yes, how should I do to modify Print Widget.
Naty
RobertScheitlin__GISP
Naty,
   It is possible but it is not a modification of the print widget it requires you to use the print service on your ArcGIS Server (not esri's print service) and then you can edit the defult template on your server to add the logo and custom text.
