Host a Web AppBuilder (Dev) App on Web Server
11032
18
12-11-2015 09:17 AM
DeannaBurke
DeannaBurke
Yes, but, I need a port number for the redirect uri, don't I?
RobertScheitlin__GISP
Deanna,
  No once you deploy the app it does not need a port specified.
http://gis.calhouncounty.org/WAB/V1.3/widgets/eSearch/index.html
Step 7 needs to be updated in the app deployment help doc.
Jianxia Song
Jianxia
By default, the port number is 80 if you don't specify it.
Robert--I will make it clear in the doc by adding a note. Thanks for your reminder.
Jianxia
DeannaBurke
I got it!!!
The redirect URIs should be http://[SERVERNAME] and https:[SERVERNAME], and the URL for the application should be http://[SERVERNAME]/appname.
Thank you so much for all your help!
Deanna,
  Don't forget to mark this thread as answered if you feel your question has been answered.
MegPeterson
Hi Jianxia -
If you are updating the documentation for WAB DE I think it would be helpful to note that wherever you deploy the application it still needs access to the web map.
I was publishing my web map internally on Portal and thought after zipping up and downloading I could launch my app on a public facing server - that somehow zipping it up compiled everything together like Flex does.
Jianxia
Meg,
Very good point. I will clarify it in the Deployment topic.
Jianxia
Samy_PatricioManosalvas_Granja
Hi Deanna
I am a beginner in ArcGIS
please I have a question:
it is a requirement of the WebAppBuilder have ArcGIS online or PortalArcgis?
Samy,
   Yes AGOL or local Portal is a requirement. For more details on Web AppBuilder see the help site:
Get started—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
