Geo-processing result returning zero result
2135
7
11-09-2017 07:56 AM
akshayloya
I have developed a geoprocessing service as below.
I'm then consuming it in web app builder with following code:
var lineSymbolQuery = new SimpleLineSymbol(
SimpleLineSymbol.STYLE_DASH,
new Color([255, 0, 0]),
3);
this.geometryService = new GeometryService(this.config.queryLayer.geomService);
var params1 = new ProjectParameters();
params1.geometries = [result.features["1"].geometry];
var outSR1 = new esri.SpatialReference({ wkid: 32646 });     ///because my data is in this spatial reference
params1.outSR = outSR1;
this.geometryService.project(params1, lang.hitch(this, function (projectedPoints) {
projectedPoints;
LARService.setOutSpatialReference(outSR1);
/*var inputProfileGraphic = new Graphic(result.features["0"].geometry, null, {
OID: 1
var clickPointGraphic = new Graphic(result.features["0"].geometry, lineSymbolQuery);
var inputLineFeatures = new FeatureSet();
inputLineFeatures.features = [clickPointGraphic];
var params = {
"Route": inputLineFeatures
LARService.execute({
params
}).then(lang.hitch(this, function (results) {
results;
This model works completely fine on ArcMap but I get a null result when I execute through web app builder. Can someone please help me understand where I'm going wrong.
Thanks in advance.
Tags (1)
RobertScheitlin__GISP
Akshay,
You have:
So the results of the project are called projectedPoints but you are latter in your code using:
I am not sure where result.features["0"].geometry is coming from in your code...
akshayloya
Hi Robert,
I was trying with another coordinate system but anyway it doesn't have any impact on the result. I still get 0 features as result.
and result.features[0].geometry  is my result which I getting from fetching route data using query. I'm passing this to my GP service for the Parameter value.
Akshay,
  So is the input geometry a point or a polyline? When it works in ArcMap what is the spatial reference of the input geometry? I don't like helping on GP widget stuff because people normally say it works in ArcMap but not in X. Well there are many things that would possibly prevent it from working in Xand yet work in ArcMap just fine. There is the whole scratch workspace thing and several others. But is could just be that you are just not getting the input param correct.
akshayloya
Hi Robert,
I understand the pain. Sorry for that name confusion. It is a polyline.
Secondly, I have just one param which is a result set for that I'm simply passing my result from a query as mentioned above and spatial reference is the same as my data, so I don't see a problem there.
Akshay,
  So I don't see the issue either then. Does the GP create a featureclass or anything server side? Have you checked the server logs for clues as to what is going wrong?
akshayloya
It returns a table and a feature class. No warnings or issues in the logs. I'd checked that.
Did you change the server log to verbose or detailed?
