Generate Demographic or Infographic Report Widget
1144
02-05-2019 10:32 AM
deleted-user-0eS87ljx3Rcy
Is there a widget where if you click on any area of the map (or search by address) it generates a demographics report or infographic summary ? Like Business Analyst Online but I want to add it to my web map application. I could not find this functionality on any of the standard widgets.
Thank you!
RobertScheitlin__GISP
Ricardo,
   So the Infographic widget does not suit your needs?
Infographic widget—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
It does not work. I want to be able to click on the map area and then generate a report from a list.
Thank you though.
