Filters and case sensitivity question?
3864
11-21-2014 02:00 PM
VenusScott
Is there a way to make the alpha characters in the filter widget to allow either upper or lower cases?
I'm finding that it's case sensitive and need it NOT to be.
RobertScheitlin__GISP
Venus,
   They have not added that to their UI as something that can be configured. It is actually noted as an issue in the Beta 3 release notes. But you can work around this by manually editing the sql syntax in the config_Query,json.
Look for your "expr" attributes like this example:
"expr": "Crime_Type LIKE 'Drugs%'"
  and adjust it to this:
"expr": "Upper(Crime_Type) LIKE Upper('Drugs%')"
Venus,
VenusScott
Thanks Robert!
Sure thing.
   Don't forget to mark the thread as answered by clicking on the "Correct Answer" button on the reply that answered your question.
