Filtering a webmap layer within a web appbuilder application on startup
10846
24
05-24-2017 01:03 AM
SvivaManager
Is there any way for me to filter a layer on startup of an application?
My current solution was to publish the same layer twice in a web map service. One layer shows all records. The other one is filtered by date.
I want to have only one layer published and when the user starts the appilcation, filter it by date and let him do as he pleased.
Is there a way to configure a widget with a certain filter to kick-in on startup?
Regards,
Shay.
DasheEbra
@RobertScheitlin__GISP  I want to apply same approach on Group Filter widget, could you guide me!
also if it possible I want to render selected layers only from the Group Filter selection but if no selection then no layers  appeared (same as Render only when selected in Dashboard).
VarmaThulasi
Hi, Robert Scheitlin, GISP‌,
I also have the same requirement, When a user open the app, Firstly the Filter widget need to be open / pop up and request the filter value. I tried with your code and ended as with an error message. I am using Developer Edition 2.12 and my post create Function code block is different as you specified here.
this is my post create function:
 postCreate: function(){
        this.inherited(arguments);
        this._store = {};
        this.layerInfosObj = LayerInfos.getInstanceSync();
        this.filterUtils = new FilterUtils();
        this.filterManager = FilterManager.getInstance();
        if(this.config.allowCustom){
          html.setStyle(this.showCustomButtonNode, 'display', 'block');
          jimuUtils.initLastFocusNode(this.domNode, this.showCustomButtonNode);
          this.own(on(this.customFilterContainerNode, 'keydown', lang.hitch(this, function(evt){
            if(evt.keyCode === keys.ESCAPE){
              evt.stopPropagation();
              focusUtil.focus(this.customBackNode);
        var existAskForValue = false;
        var filters = this.config.filters;
        //set filters's order by layer
        if(this.config.groupByLayer){
          var newFilters = {};
          array.forEach(filters, function(filterObj) {
            if(!newFilters[filterObj.layerId]){
              newFilters[filterObj.layerId] = [];
            newFilters[filterObj.layerId].push(filterObj);
          }, this);
          var lastFilterKey = '';
          for(var _key in newFilters){
            lastFilterKey = _key;
          for(var key in newFilters){
            // for(var key = 0; key < newFilters.length; key ++){
            var layer = this.layerInfosObj.getLayerInfoById(key);
            // var layerName = this.layerInfosObj._getLayerTitle(layer); //don't use private function
            var layerNameNode = document.createElement('div');
            html.addClass(layerNameNode, "filter-layer-name");
            layerNameNode.innerText = layer.title;
            html.place(layerNameNode, this.filterList);
            var isCheckLastNode = (key === lastFilterKey) ? true: false;
            existAskForValue = this._initFilters(newFilters[key], existAskForValue, isCheckLastNode);
        }else{
          existAskForValue = this._initFilters(filters, existAskForValue, true);
        if(!existAskForValue){
          html.addClass(this.domNode, 'not-exist-ask-for-value');
Varma,
   I see nowhere in your code that you are calling:
query('.header', node)[0].click();
VarmaThulasi
Dear Robert Scheitlin, GISP‌
Please can you explain little bit ? Where I need to place this code. I have only one filter widget in my app and its have two filter. Thanks in advance.
Varma,
  Look at the original correct answer on this thread I point out that lines 38 - 40 are what need to be added to make the widget automatically run the query that is named ParksFinder in the widget.
