Has anyone had any issues with the Filter Widget when using it against a layer with subtypes set up.
I have a service that is setup to show the layer broke up with its multiple subtypes. When I set up the Filter Widget to use on one of the subtypes, the filter applies sort of. I can only select the features that meet the filter requirement, HOWEVER, the features that don't meet the filter requirement is still being displayed. I just cannot select them. If I create a service with the same data but don't break the layer into subtypes and then apply the filter, the features that don't meet the filter requirements disappear so I only see the filtered items.
This data is pretty robust and I have special labeling and symbology set up per subtype so it would be nice to utilize that instead of not using subtypes and trying to get that all set up through filters in the Map Viewer.
I'm using Map Viewer Classic and Web App Builder through my 10.9.1 portal.
