Hello everyone. Does the web appbuilder Filter Widget have a limitation on how many records/rows to display? I have a FC of over 5000 records of names and after applied it to the Filter Widget in the drop down list, it is only showing alphabetically up to "E", which is around 300 records/names. Anything after "E" is not showing. Thanks in advance for any comments/help.
I have found the answer. I just have to adjust the parameter of the FC map service in ArcGIS Server to allow more than 1000 records to return when query.
