Field as Link for Related Records
3649
08-26-2015 07:52 AM
mpboyle
Honored Contributor
Does anyone know if it's possible to have a field from a related table act as a hyperlink rather than just static text...?
DanNorman
Hey Matt, did you ever find a solution to this? Hopefully this bumps the thread up in the list too...
mpboyle
Honored Contributor
This is possible with the latest WAB on AGOL.  I'm assuming this is within WAB Developer Edition 2.1, released in July 2016.
The screenshot below is showing a related table within the Attribute Table widget.  The last column contains a hyperlink to a PDF document.  The app was made with WAB inside AGOL, so I can't confirm if using WAB Developer Edition.
DanNorman
Thank you for the quick reply. Great to see that is coming, looks like 2.1 was just released so I will take a look.
Thanks!
