Extract Data by Intersection
6657
29
02-27-2017 04:15 PM
deleted-user-iwYtitJHBIyn
I have two distinct layers; one containing polygons representing HOA boundary limits and another featuring our City Parcels.  Is there a widget (or method for that matter) that I can use to obtain all Parcels intersecting a selected HOA in ArcGIS Online?  I know I can use the select tool but I was hoping to utilize something very similar to the Intersect function in ArcGIS Desktop.
Many thanks in advance.
Jeff
RobertScheitlin__GISP
Jeff,
  Can you zip and share your config_eSearch.json with me?
Robert,
Please see attached.
Thanks.
Jeff
Robert,
Please see attached config_eSearch.json.
Thank you.
Jeff
Jeff,
  I am not sure what the issue is here. Does the unique work for other fields?
Robert,
No. I've tried others and like HOA Name the dropdown is completely empty.
Robert,
Would it have anything to do with this widget being developed for WAB 2.3 and we are using 2.2?
Thanks.
Jeff
Not that I know of. What version is your ArcGIS server that the layer you are using?
Believe it or not I just go it to work.  I ended up removing it entirely and re-added the widget.  Works great!
Thanks Robert.
Jeff
Jeff,
   That is great. I have been struggling to figure out what might be going wrong.
Robert,
This tool will definitely come in handy and I am so glad it all worked out.
Once again, thank you for all your guidance and for assisting me in the process.
You are to be commended.
Jeff
