eSearch
1914
02-25-2016 01:44 PM
LianaSmith
How can I change the color of the selection?
RobertScheitlin__GISP
Diana,
      Sure you can set the selection color by using the Edit default symbology link at the bottom of the widget configuration UI (if you are using symbology from defaults for "Layer Symbology"). If you have the Layer Symbology set to "from server" then you do not have control of the selection color as it is obtained from the server directly. If you choose "from layer" then you can choose "Add/Edit Layer specific symbology" then you can choose the selection symbol for this specific layer.
Diana,
LianaSmith
Thank you, Robert!
