Enable or disable Web Appbuilder widget based on logged user
2316
05-13-2020 10:00 PM
Shalineemishra
In my web application I am able to add widgets and also change the rights of widgets from confing.json file,But this change is permanently. And I want the property of the widget to be enabled or disabled programatically at the run time using java-script API.Please suggest how to do it.
RobertScheitlin__GISP
This is going to be a pretty advanced subject, but I have answered this before:
https://community.esri.com/thread/174605
Shalineemishra
Thank you for reply..I am new for Web Appbuilder, so can you please tell which file to add this code.
You have to carefully read that thread. The code was added in a custom widgets widget.js file. As I mentioned this is a pretty advanced task.
