Hi All,
I am wanting to get the web app builder for developer (v 2.17) smart editor widget to only show a subset of feature templates.
The problem I am having is shown below.
I have a feature service that is symbolized using two fields. I have then grouped values to get the layer to symbolize the way I want.
When I add this layer to the editor widget I get a bunch of templates that I don't want to present to users.
Is there a way to hide some of the templates so users are unable to select them when creating new features?
@AlixVezina can you describe what you mean by this "If you did make changes in the web map, you would need to make sure those changes are saved against the hosted layer / service endpoint - but the behavior there could be inconsistent."
or even better, have a look at my question here
https://community.esri.com/t5/arcgis-web-appbuilder-questions/editor-widget-missing-choice-in-featur...
thanks 🙂
