Edit Widget - attribute popup not working?
2996
11-03-2014 11:41 AM
BrendanWalashek
Hi, I have use WebApp Builder (WAB) to build an application to add point utilizing the EDIT Widget.  The edit widget works fine on a Windows based web browser, and I'm able to select the widget, choose the feature to add, click on the map, which then invokes the Attribute Editor popup window.
Now when I use the App on ANY mobile phone (Android, iPhone, Windows Phone), everything works fine until you drop the point, then the Attribute Popup does NOT show up - instead, just the 'identify' window shows up with all attributes 'blank' as I never had the chance to add any!  Is there something I'm missing here?  Fully functional on running the exact same WebApp in a browser on Desktop form factor, but any mobile device, no ability to add attributes on new points, nor on existing ones!  Ideas?  Anyone have it actually working??
