Edit Widget AGOL and adding Points (lat/long)
1193
12-12-2019 11:34 AM
kmsmikrud
I've recently added a point/line feature layers to WAB for folks to edit. I've added fields for latitude/longitude to the point layer. I was hoping for clarification on the edit tool for points.
Can a person add a point via the edit tool by specifying a lat/long? Or can the lat/long be extracted similar to calculate geometry used in desktop versions for the new point? We want to display the lat/long as labels. Currently the work around is to use the Coordinate Conversion widget to either navigate to the lat/long and also to find the coordinates to the edited new point. Then by hand add the lat/long values to the table based on the coordinate conversion tool.
Thank-you!,
Kathy
