Dynamically add text to Header in WAB
5405
7
12-19-2015 04:32 PM
MeleKoneya
I may not be using the correct term but what I would like to do is to add some text to the title bar or header are in WAB application based on the selection made in another widget.
How can I add some text dynamically to the title bar?
RobertScheitlin__GISP
Mele,
  The simplest way would be to manipulate the dom element directly:
Require: 'dojo/query'
var appTitleNode = query('.jimu-title.jimu-float-leading')[0];
var appTitle = appTitleNode.innerHTML;
appTitleNode.innerHTML = appTitle + " my added string";
Mele,
   Are you talking about the Header controller widget in the foldable theme?
MeleKoneya
Yes, Robert,  that is what I was looking to do.    Add some text dynamically to the Header Controller Widget below.    I would like to add something at the end of 'Hydrant Maintenance Program'.    It looks like this is the Title which is set in the config.json file.
Mele,
MeleKoneya
Robert,  this is perfect!   Thanks for all your help!
DanNorman
Hi Robert, I added 'dojo/query' to the end of this list which is at the beginning of a widgets Widget.js file (In your map progress widget). Is that all I need to do to "require" dojo/query?
Thanks!
define([
    'dojo/_base/declare',
    'dojo/_base/lang',
    'dojo/on',
    'jimu/BaseWidget',
    'esri/dijit/util/busyIndicator',
    'jimu/utils',
    'dijit/registry',
    'dojo/dom-style',
    'dojo/query'
Dan,
   That should be it as long as you are adding a var for the require as well (line 10):
function(
    declare,
    lang,
    on,
    BaseWidget,
    busyUtil,
    utils,
    registry,
    domStyle,
    query) {
DanNorman
Ok Robert that's what I missed and now it works thank you very much!
