Disable maximise/minimise option for widget in Dashboard Theme WAB
1688
01-25-2018 05:49 AM
deleted-user-GKyg-xriCvci
Hello, I am struggling with customizing my Web App and I hope someone can help me. While using Dashboard Theme, all the widgets on dashboard by default have an option to maximise them. (Picture below).
I am using WAB Dev Edition to customize my apps but I can't find any settings which could disable this functionality or at least hide this icon. Also, the same for widget label, is there a possibility to hide it?
Any help would be appreciated.
RobertScheitlin__GISP
Aleksandra,
  Sure you can simply add a new css rule to the themes\DashboardTheme\common.css:
.lm_header .lm_controls .lm_maximise,
.lm_header .lm_tab .lm_title {
  display:none;
Aleksandra,
  display:none;
It worked. Thank you very much Robert.
