Disable Edit widget if public access
1423
02-29-2024 05:40 AM
Rémi
Hello,
I've created an application (WAB) for internal departments and the public. Currently, anyone can access the application and edit the data. I'd like only internal departments to be able to edit the data.
Regards,
GeeteshSingh07
@Rémi , you can once test this workflow and verify if this resolves the issue:
1- Disable editing on the layer and disable 'Public Data Collection':
2- Create a group with "Shared Update" capability enabled & add your organization members to the group.
3- Share the item publicly (web map, hosted layer & web app) and in this group.
The members of Shared Update group can edit the features.
Best Regards,
Geetesh
[email protected]
GeeteshSingh07
I just found this, here 2 workflows are suggested, you can use any one: https://support.esri.com/en-us/knowledge-base/faq-is-it-possible-to-assign-the-editing-capability-of...
@Rémi
Best Regards,
Geetesh
[email protected]
Rémi
Thank you for your answer. Unfortunately, I work with a feature layer and not with a hosted layer. Is there a solution for me?
