Directions widget - Using my NA service
1275
02-24-2017 04:06 PM
ShawnCarson
Hello Everyone,
I have an issue with the Directions Widget in WebAppBuilder using a NetworkAnalyst service I published w/ ArcGIS Server 10.2.2
PROBLEM:
When I add the url of  my service and use the Directions widget in WebAppBuilder, the Get Directions  button stays greyed out. (see image below).
(If I use the default Route_World service it works.)
CLUES/INFO:
My NA service works if I add it to ArcMap and use the Find Route tool in the Tools toolbar.
(I add two stops, click Find Route and it makes a route.)
I am seeing no error in Chrome debugger.
I get the same behavior in IE and FireFox.
I created the NA service with Server 10.2.2
Thanks everyone - Shawn
It puts the stops in the correct location...(#1 & #2 below)
Issue
deleted-user-5IaUWKgFepbf
I had the same issue but it turned out that the url for my route service was missing "Route" at the end. It should be in the format "https://...............NAServer/Route" instead of "https://...............NAServer"
