Decimal degrees in Search Widget
2234
01-24-2016 04:30 AM
IsraelShpindel
I'm using the Search Widget with a Feature Layer of parcels. The search itself works fine, but when I click on any search result, the map zooms to the same wrong location.
When I check the variables in debug mode, I see that the geometry of the relevant feature is not represented by its full coordinates, but by rounded values (e.g. "35, 31" instead of "35.23932, 31.77802"). Since all the features are in the same area, that explains the wrong zoom behavior. Is there a way to fix it? Isn't it possible to work with decimal degrees in this widget?
