Crowdsource Manager Report could not be submitted.
3281
11
01-19-2023 11:41 AM
LaurenCammack01
I have a permit management application that is run through the crowdsource manager web appbuilder. They would like the past year's worth of submissions filtered out but leave ones with an approved status. I have placed a definition query on the service to accomplish this filter; however, now in crowdsource manager I am unable to make edits on that status field. I am able to make edits on other fields in the same layer.
I am able to change the status in the feature layers item description area where the table is viewable.
The goal is that when permits from last year are changed to a status of 'Completed' they will disappear from the viewable dataset in Online.
Is it a known limitation that whatever field you have a definition query on will not be editable in crowdsource manager?
Thank you!
LaurenCammack01
Thank you so much for the assistance!
WC48
I had a similar issue. I mistakenly was "saving" refinements to the hosted feature layer, when it should only be saved to the web map that the manager app drawing from. The same would apply for setting "view" definitions. If saved to the hosted feature layer it breaks the manager app. Be sure to track your revisions just in case you need to revert back.
